rev counter/tacho for track bike
nick
Post by nick »
I've done a search and so far i've not found the answer i'm looking for, so hopefully someone out there can help.
I'm converting my 4dx to a track bike and as such i'm not planning on using the clocks. Is there another model in the FZR range that could provide just the tacho (earlier 400 perhaps) that i can plumb into the loom?
Also, i'd like to rig up a neutral light and the oil light as these would be kinda handy. Do i just find the relevant wires that go into the clocks and connect them up to a couple of bulbs?
I'm not the most 'electrically' minding so any help on the wiring would be greatly appreciated.
Cheers,
Nick.
Re: rev counter/tacho for track bike
Post by Evilchicken0 »
The best thing would be a 3TJ / 4DX tacho ... I've seen some bikes with the speedo just cut off.
Yup - your right about the neutral and oil pressure light just trace the wires in the back of the clocks
mogster
Post by mogster »
I have a set of 600 clocks on my 3tj hybrid , I cut the speedo off and left the rest then made an aluminium dash board sort of thing to support the rev counter and temp gauge and the rest of the light in side the fairing , if i can figure out how to post some pics i would as i'm just finishing off the project at the minute
nick
Post by nick »
Can i use a tacho from just about any 4 cyl bike (with the appropriate rev range)?
mogster
Post by mogster »
No........ most tachos are all calibrated ( for want of a better word ) different the guy from Elliot Tachos explained it to me when i was looking for one for my fzr400 race bike apparently the same tacho for a cbr 400 works on an fzr 400 3tj CDI if thats any use .
fzrtim
Bike owned: FZR400 FZRhybrid FZR600 RSV1k
Post by fzrtim »
My trackbike has a scitsu tacho. It has a nicad battery inside and will work for up to 8 hrs without a charge. Doesnt use any of the original wiring, it just has 1 cable which you attach to 1 of the ht leads. Ideal if you are running total loss electrics.
nick
Post by nick »
fzrtim wrote:My trackbike has a scitsu tacho
Best place to get one.......?
mogster
Post by mogster »
Those Vapour digital dashes have the same idea with one wire to wrap round one of the HT leads , gives you speed and water temp as well . they can run on a 9v battery , worked OK on a Power-Valve track bike i had . I also ran an Elliot Tacho on my F400 race bike , 3 wires + , - and a single wire from the original tacho . They are a bit sensitive to volts , so if you are running total loss the scitsu the one to have .
nick
Post by nick »
Looked at the Vapor stuff, but it seems to be for off road bikes, is there one for road bikes?
Taggyd
Bike owned: fzr 400 3tj x 2, cbr900rrs
Post by Taggyd »
yep i got one! not fitted proper yet though!
