3TJ Headlight
				ROB-RD350
3TJ Headlight
Quick question, can you replace the 400 3TJ headlight with one from another model like the 600 with normal uk bulbs?
Done a quick search but didn't find any answers.
Thanks in advance
Thanks in advance
				plodder
Re: 3TJ Headlight
Yes, the one for the FZR1000EXUP 1991-92 has a single H4 bulb in the centre
It does fit behind the 3TJ central bracket but it's a bit of a squeeze.
Changing the bulb looks just about possible in situ but only just.
I changed mine after both the projector bulbs blew and it was cheaper to get the H4 headlight than 2 bulbs for the projectors.
				ROB-RD350
Re: 3TJ Headlight
Thanks for that, any pics of yours?
Anything else need doing, any wiring etc?
Re: 3TJ Headlight
If you get the 1000's loom with it, then it will have the H4 fitting.
There are other bikes that have the same fitting too - FZR600, TRX850 etc.
You should probably fit a relay to be on the safe side
				plodder
Re: 3TJ Headlight
Yeah, splice the H4 connector block on in parallel to what you've got so you can revert to projectors later if you want to.
You don't need a relay... you're reducing total load. I'm beginning to think that Evil has shares in a relay company.
Got no pics. Trust me it fits but it's just tight. There's nothing on evilbay at the moment anyway.
Re: 3TJ Headlight
Nah - I put some lamps on the Bimota and they were fine ... then they didn't work and I found the wires broke dure to heat cycling. There wasn't even a difference between the total voltage draw ....
I usuually play safe on the forum, I don't want to say yeah chuck something in and have it damage anything
				ROB-RD350
Re: 3TJ Headlight
Had a look earlier and as you say, nothing on thereThere's nothing on evilbay at the moment anyway
 Thanks for the help guys, will keep checking on ebay till one comes up
				drjkill
- Bike owned: Cbr1000rr,Nc35,3TJ & Rg500
Re: 3TJ Headlight
i've got a 4dx1 normal bulb headlight on spare
if somebody wants it....
				plodder
Re: 3TJ Headlight
I tell people exactly the same as I have done myself without problems. If mine had a problem then I would recommend otherwise but I am an engineer by profession and don't overdesign or overcomplicate matters more than necessary, either at work or in my own garage.Evilchicken0 wrote:Nah - I put some lamps on the Bimota and they were fine ... then they didn't work and I found the wires broke dure to heat cycling. There wasn't even a difference between the total voltage draw ....
