a
shahidmajeed
a
Post by shahidmajeed »
aa
bikerbiffo
Re: Power loss at 5k Rpm cb400sf
Post by bikerbiffo »
has the bike been stood?
have you tried revving it's a****e off for a few miles to see if it clears up
i say this b
because i run a kawasaki zx9r and when it's been stood for a period
the bike struggles at about the same revs as yours
i either let it warm up on drive then wack the throttle open to the red line 2 or 3 times
or take it for a spin a revv it's a****e
it then runs like a watch until i put it away for winter again.
as for cdi wouldn't have thought it would be different if off same bike
martin
craigs23
Bike owned: Quite a few
Post by craigs23 »
I had exactly the same problem. It's a common fault. See my thread further down this section called 'Superfour misfire around 5,500rpm'
shahidmajeed
aa
shahidmajeed
aa
craigs23
Post by craigs23 »
Should do, so many Hondas carry this wire - even Dad's Hornet, that doesn't have a speed restrictor.
Open up the headlight - you should find two clusters of wires running from the loom to the clocks - you want the larger of the two clusters - the wire could look a little darker with age but it should be there. Your symptoms are pretty much identical to mine - even after going to lengths of changing the coils, leads, plugs, sorting and balancing the carbs, etc, my bike's problem ended up being that silly little wire. Not sure if the old forum archives are still up and running, but I found quite a bit of useful (and detailed) information there.
Here's the wiring diagram of an early CBR400 - the clusters and colour of the wires (as well as their routing) is identical to my 1993 Superfour.
If you've still got the problem by the weekend - I'll take my Superfour's headlight apart and take some photos of what I did.
shahidmajeed
:pmsl:
meno
Post by meno »
havent got my bike to look at anymores but, on the pic u have of the back of the clocks im pretty sure my speed limmiter wires went thru where the black grommet style thing is.. which in your pic theres nothing. this maybe suggests sum1s removed it but not done the resistor mod maybe? all speculation ofc and doesnt rly help u :(
shahidmajeed
:blah:
meno
Post by meno »
surely thats the wire sat there with nothing going to it in pic c00276..... bit with the rest that connects to teh speedo missing.. ???
wish i still ahd mine id rip it apart and see for ya m8 :(
