generator burning out
- Bike owned: nc30 grey
my nc30 keeps frying new generator in a month any ideas
- Bike owned: ktm200exc gsxr400gk71b sv650
Re: generator burning out
could be faulty reg/rec or may have wiring fault ( rubbed through onto frame ) shorting out ? or just unlucky and fitted a set of windings that were on there way out ?? . i have a set of windings and a reg/rec someware i have removed off my track bike , they wont be going back on so you can have them if you want em for postage cost
As Kev has said.
Check your Reg/Rec & Battery.
Usually if your charging systems so bad the gennys died, the RR and battery are usually long gone too.
http://www.electrexworld.co.uk/pdfs/Tro ... G-&-RR.pdf" onclick="window.open(this.href);return false;
Follow that through starting from the top and making sure your batterys fully charged before you start :)
The usual casue of the genny dying is reg/rec failure which is usually caused by an old / abused battery.
The NCXX's have a rather flimsy Reg/Rec unit, riding with the lights on all the while, short journeys etc takes it toll on the battery.
Also, as a battery ages anyway it looses the ability to take charge as quickly.
The Reg/Rec has to burn excess energy off as heat, the poorer state the battery is in the more heat the reg rec has to burn off, the general concensus is that the heat kills the reg/rec.
Now one or two things will happen, your battery will be over/under charging. Either way if left is bad, also your genny gets burned out. Under-charging is generally worse as you notice it last as the battery will keep goign for a while off the generator until its died.
Best solution after finding the problem(s) is to use a decent new battery and connect it to a smart optimising charger like an optimate/datatool at least once a week to fully renew the battery.
You can pick up a decent Varta for £20'ish.
It's usually always the battery / reg/rec that have / are killing the genny but there could be wiring shorts too so dont' neglect to fully check over the wiring system after diagnosing the rec/rec & battery.
Hope that helps.
Hope that helps.
nice 1 just bourt new 115pound guttedkevprojex wrote:could be faulty reg/rec or may have wiring fault ( rubbed through onto frame ) shorting out ? or just unlucky and fitted a set of windings that were on there way out ?? . i have a set of windings and a reg/rec someware i have removed off my track bike , they wont be going back on so you can have them if you want em for postage cost.
Neosophist wrote:As Kev has said.
Hope that helps.
nice 1 thanks oreded rec and genny hope this sortets it out when the bike get hot the temp garge go crazey even when the bike is not running its all over the place till the bike cool down it all right it must be the rec when it hot sending out volts to the the elec of the bike
mad
A wigge dout temp gauge is often the sign of a loose earth connection.
Get them checked and you might find it is solved..
good luck
good luck
they all right my mate check them . and the best thing about things is my best mate is a honda bike mac workes for honda did know wots wronge with my bike . thanks 2 u all told him wot him wlot u said he sorting itCMSMJ1 wrote:A wigge dout temp gauge is often the sign of a loose earth connection.
good luck
good luck
Pull the earth off the temp gauge and it goes to the top... if yours is doing this you have a bad earth somewhere.
This might not be related to the electrical problems though, it could just be another problem!
put the new gen and rr and the bike is only chargeing at 12.35 revs it too 6rpm it goes down too 12.05 put the old rr revs the bike 6 rpm 1305 someone said it might bee the :magnetoe: sorry about the spelling of it any ideadsNeosophist wrote:CMSMJ1 wrote:A wigge dout temp gauge is often the sign of a loose earth connection.
good luck![]()
Are the RR and generator new?
Have you also changed the battery?
