Does HRC slide works for NC29 carbs ?
PARUS
What do you think guys. Does anybody use this ?
stimpy
Re: Does HRC slide works for NC29 carbs ?
trick..
maximum airflow
stimpy
maximum airflow
stimpy
PARUS
So, it does. Correct?stimpy wrote:trick..
maximum airflow
stimpy
I have them in my nc30 carbs. They'll also probably fit the nc23 carbs (VD series).
They won't fit the nc29/nc35 carbs (VP series carbs).
Forget paying big $$ because the seller says they're hrc parts, the nc24 model vfr has them standard...
PARUS
Thank you mate. I thought that slide on NC30\NC29 is identical.Stickshift wrote:I have them in my nc30 carbs. They'll also probably fit the nc23 carbs (VD series).
squirrel_hunter
Stickshift wrote:They'll also probably fit the nc23 carbs (VD series).
Did I just hear the price of NC24 carbs going up.
Right I’m a NC23 owner. What is this mod and what does it give me? And what are VD series carbs?
stimpy
squirrel
just fit nc29 carbs to your 23..propper alloy trumpets,and a flat slide
only tricks are disconnecting the tps,running a nc29 throttle cable,and making a mount to suit the 23's airbox
they work really well.
stimpy
stimpy
squirrel_hunter
Cheers Stimpy.
drew70
been using nc24 carb slides in my nc23 carbs for a couple of seasons now, a very worth while mod .
