shock removal NC30
Dgeoff33
Bike owned: RVF400 - ZX636
shock removal NC30
Post by Dgeoff33 »
Is it possible to remove the rear shock without taking the exhaust off?I have a nice Maxton shock I need removing before the bike is sold and it seems impossible without taking the exhaust off,which I would prefer not to do.
Thanks in advance.
hannakournikova
Bike owned: NC30, NC35 & SP2
Re: shock removal NC30
Post by hannakournikova »
is it a standard exhaust geoff??
Dgeoff33
Post by Dgeoff33 »
it certainley is
hannakournikova
then your gonn have to remove it chum.
i managed to fit my nitron with half the exhaust on, as it was an ethos system.
but tried removing a shock with a std system on....system still hanging up im my garage, but the bike isnt...lol
Dgeoff33
Post by Dgeoff33 »
gonna have to bite the bullet then,eh.Best get a good price for the shock to pay for the new gaskets and extra hard work :lol:
hannakournikova
hahaha, £5 for gaskets, think youll survive matey...
fastdruid
Regular Member
Post by fastdruid »
IIRC it depends on which way the bolts were put in, dunno about the NC30 but ISTR on the NC35 it's possible if the shock[1] bolt was put in from the wrong side.
Then again it might just be possible on the NC35 anyway, I don't recall removing the exhaust when I swapped shocks on our NC35 but it was some time ago! I certainly could *fit* a shock to an NC35 (with an NC30 exhaust) but one of the bolts had to be fitted the wrong way round.
Still, you may as well attempt it without removing the exhaust, if it turns out impossible you've not lost anything, if you need to remove the exhaust it's just £5 worth of gaskets. May as well first see if you can get enough room by unbolting the silencer and moving it slightly.
Druid
[1] I think, may have been one or more of the linkage bolts.
Cammo
Post by Cammo »
fastdruid wrote: Still, you may as well attempt it without removing the exhaust, if it turns out impossible you've not lost anything, if you need to remove the exhaust it's just £5 worth of gaskets.
that's assuming you don't snap one of the buggers when removing them. :(
Rick1138
Post by Rick1138 »
i was able to remove my old shock and replace it with a nitron one without having to touch the exhaust system.
its a bit of a fiddle, and some bricks to hold up the swing arm helps, and you have to put a bolt back in the wrong way round (it doesn't actually make any difference).
However its a bit of a fiddle, but i really dont want to be trying to take off exhaust head bolts!
that will often end in despair of doom and darkness, followed by much swearing! :D
fumb
Post by fumb »
Haynes gives you 2 options of removing the shock, with the exhaust in place or not. So it must be possible.
