RVF400 forks
brido
RVF400 forks
Hi there can someone tell me if rvf400 forks fit into vfr400 yokes without any modifications or if there is any modifications, what they are? Also is there any advantages from fitting rvf400 forks as opposed to the standard vfr400 forks?
cheers....
cheers....
- abrmoto
Re: RVF400 forks
Oow you are going to get it from some of the funny folk on here................................
Use the search box at top of page, ssshhh I did not tell you
Re: RVF400 forks
lol.
No - they are obviously different.
The internals are the same.
hows that?
hows that?
- royster81
Re: RVF400 forks
you'll need rvf forks (funny enough) rvf yokes, clip ons,calipers, lines ,mud guard ,spindle, spacers,rvf-nc30 fitting kit ( off rick oliver) .so no unless you have deep pocketsbrido wrote:Hi there can someone tell me if rvf400 forks fit into vfr400 yokes without any modifications or if there is any modifications, what they are?....
they look good, erm ...are a bit firmer ....er ..erm ..you can adjust them a bit more ???brido wrote: Also is there any advantages from fitting rvf400 forks as opposed to the standard vfr400 forks?
cheers....
fwiw get rick olvers fork spring kit into your front end and it'll be right !
- Martin
Re: RVF400 forks
The most important difference and one that will see most gains is that they're.......
Gold
Gold
Too spensiff!!!
