NC35 hi performance air filter--- looking for one
drjkill
Bike owned: Cbr1000rr,Nc35,3TJ & Rg500
Post by drjkill »
hi im looking for an air filter like bmc or k&n
i'd prefer a street one in case but if not a race
one should be fine...
where i can get one,buy it or has anyone got one on spare?
thanx
Re: NC35 hi performance air filter--- looking for one
Your best bet is a standard Honda one. Unless you want to make your own from foam... ;)
Spike16
Post by Spike16 »
I got one you can buy, its a honda original one with the paper element cut out and a dual density foam element put in its place. New never been used
you can have it for £15 posted but it will mean your bike will need re-jetting as they are alot more efficient than the original
drjkill
Post by drjkill »
Spike16 wrote:I got one you can buy, its a honda original one with the paper element cut out and a dual density foam element put in its place. New never been used
for me its ok, buut im based in ibiza,spain
so i supose p&p has to be a little bit more
im looking for a air filter like that because
im putting a rick oliver hrc carburetor system
a full tyga exhaust system and the extended
8% plus airbox also from tyga.
do you accept paypal?
thanx
Spike16
Post by Spike16 »
postage to Ibiza make it £18 posted, yeh il except paypal
drjkill
Post by drjkill »
you've got a PM
I would advise against using the 148 or higher jets that you'll get in the HRC kit. It will be too rich by miles.
The moto should go like the clappers though so you'll have to let us know how you get on :up:
drjkill
Post by drjkill »
CMSMJ1 wrote:I would advise against using the 148 or higher jets that you'll get in the HRC kit. It will be too rich by miles.
ill take in count that advise...
Spike16
Post by Spike16 »
yeh but with the performance filter you will need alot higher jetting, which btw will be posted 2moro morning
drjkill
Post by drjkill »
Spike16 wrote:yeh but with the performance filter you will need alot higher jetting, which btw will be posted 2moro morning
probably ill follow the hrc guide
id like to knowwich is the gain with
theese sweeties? 60-62 bhp?
