Play in rear wheel.
dickdastardly
Play in rear wheel.
Post by dickdastardly »
Basically, what else could it be apart from shot bearings?
Thanks.
greggo
Re: Play in rear wheel.
Post by greggo »
Flogged cush rubbers, knackered spindle, improperly tightened axle. Also double check it is the wheel not the swingarm. What did you do to diagnose the play at the wheel?
dickdastardly
I had it in the paddock stand I have (rear obviously) and just shifted the wheel left to right and it moved.
greggo
Post by greggo »
Add overtightened axle (crushing the wheel bearings) and your spacers to the things above to check.
There aren't really a lot of things it can be.
