Ignitech CDI (Dyno test)
greggo
Re: Ignitech CDI (Dyno test)
Post by greggo »
The particular secrets I am interested in are;
Understanding how they create a 3d map based on TPS and engine RPM, only two points of reference? (Or am i missing something)
I'm also interested in understanding what dictates the x,y,z axis ranges and how these are affected by different fuels and engine set ups.
tk400
Post by tk400 »
They do not use 2 points. The manuals just refer to these for the purpose of checking static advance and CDI functionality.
The actual map is 3D
x= RPM
y=Advance
z=TPS
cheers
Regards TK400
tk400
Post by tk400 »
Sorry its late....I misread your question. The third variable is the advance. Most bikes of the same age are 2D meaning only Advance vs RPM.
Cammo
Post by Cammo »
tk400 wrote: The actual map is 3D
x= RPM
y=Advance
z=TPS
Yep, this is typical for most engines with a TPS (e.g. most efi cars).
I've worked with turbo cars which introduce a 4th variable being intake pressure (boost). These maps are quite complicated.
TK: Do you have 3d graphs of both nc29 cdi's?
