clocks/ lights not working..
Bill
so my nc has turned into quite a project after a nice lady destroyed my front end with her car, it has most of a duc front end fitted thanks to riley
and when its nearer compleation i'll post about the whole pproject if there is any intrest and i can figure out how to up load pictures, but anyway...
as above ive got lights and clocks now fitted but when the bike is turned on only the right hand light works, unless on high beam then they both work...
while the high beam is on and i press the passing light button the neautral and oil light flash (or stay on if the button is held) and the temprature gauge moves up slightly apart from this nothing works at all.
the side lights dont work and if the bike is fired up the rev counter also dosnt work and none of the clocks lights up....
im thinking i need to change the bulbs or its a bad earth somewere but haveing no luck with it.
so has anyone had simular problems and sorted it? any sugestions or advice welcomed, thank you
Bill,
Bill,
Re: clocks/ lights not working..
sounds like you need to start from scratch with the connections and wiring.
earths sounds suspect too...
Bill
hmm seems that way, cheers for the reply and if this weather ever holds out i'll get another look at it
Cheers Bill
Cheers Bill
Bill
it all works! oddly it was a fuse, glad i check those out, just a shame i checked after i took it all back to bits a million times and not before
wullvfr
- Bike owned: zx9r c1
Bill wrote:it all works! oddly it was a fuse, glad i check those out, just a shame i checked after i took it all back to bits a million times and not before
typical eh?......remember in future and double check fuses first!!!
wull
Bill
yea it is that! the only reson i didnt check them first was because my old man was convinced it wouldnt be a fuse! but at least its done now and he fetched and paid fof them not alot i know but im not complaining :D lol
Cheers Bill
Cheers Bill
