leaking fuel tap nc24
- Bike owned: nc24 87
i have a leaking fuel tap on my nc24 when it is in the OFF poistion. the seal under the tank is good where
it bolts on with the two bolts. i have pulled the diapham off & it leaks by it self. does anyone have a drawing of whats inside the tap, or can help me please
Re: leaking fuel tap nc24
Yo butterfly, I had this problem on one of my nc30's. The easist and cheapest thing to do is just bung a small plastic inline tap between the fuel tap and the carbs, and turn it off after you stop riding. You can get suitable ones for lawnmowers etc for about a dollar.
To fix the leak properly you'll need a new fuel tap, Honda only sells the complete assembly and it's very pricey!
If your carb float needles don't seal properly there's a very real risk that petorl will fill your cylinder, bending the internals when you crank it over. It happens!
