3tj front wheel
				joshua102
- Bike owned: Gsx-R600K9 3tj NC35
3tj front wheel
Hi,I'm after a front wheel for my 1990 3tj ,If anyone has one or can tell me of a wheel from another model thats the same please let me know
Cheers Josh
						Cheers Josh
Re: 3tj front wheel
You can also fit a TRX850 and FZR600R front - theyre the same
				joshua102
Re: 3tj front wheel
cheers for that evil, gives me better chances of finding one
				KIYOSHI
Re: 3tj front wheel
Would double check that, i have a trx wheel and it is not the same, the cast code is correct (f52 i think) but the bearings you will need for the 3tj spindle are diferent. Not sure if this is true of all trx rims but the one i have was not a straight fit.
				joshua102
Re: 3tj front wheel
thanks Kiyoshi as long as the wheel is the same Ican change bearings
Re: 3tj front wheel
I used a TRX850 wheel in my 3TJ and it fitted straight in. Useful to know though.
				KIYOSHI
Re: 3tj front wheel
I think the bearing OD was larger on the TRX rim i have.
