throttle cable
vtiimport
throttle cable
I need to get a new throttle cable but just want to make sure i order the right one, is cable A (open) and cable B (close)
thanks rob
thanks rob
Simon_Ed
Re: throttle cable
might be daft but why don't replace both cables? least they're both done and no need to worry about it then :)
Morsing
Re: throttle cable
Yesvtiimport wrote:I need to get a new throttle cable but just want to make sure i order the right one, is cable A (open) and cable B (close)
thanks rob
mick.mh2racing
Re: throttle cable
Never understood why you need a cable to close the throttle. It's spring loaded so closes anyway.
How hard can it be?
fastdruid
Re: throttle cable
So when the 'A' Cable breaks you can rig up the 'B' cable to open the throttle[1].mick.mh2racing wrote:Never understood why you need a cable to close the throttle. It's spring loaded so closes anyway.
Druid
[1] Don't, unless it is a last resort, trust me on this. Your every throttle reaction is wrong.
Re: throttle cable
I've never run a closing cable, and don't see the need.
It makes it easier to get the carbs off, and easier to find alternative throttles.
fumb
Re: throttle cable
Safety issue:mick.mh2racing wrote:Never understood why you need a cable to close the throttle. It's spring loaded so closes anyway.
If throttle cable breaks when fully open and the springs breaks, your stuck on full throttle. This might not be great running into a corner. The closed cable ensures that you are not relying on a spring to close the throttle and could save your bacon.
vtiimport
Re: throttle cable
thanks for the replies, decided to replace both
tanuki
Re: throttle cable
Me neither I run a propper 1/5th turn HRC single cable throttle on the RVF and a NSR 250 (giving 1/5th turn) on the CBR track bike.mick.mh2racing wrote:Never understood why you need a cable to close the throttle. It's spring loaded so closes anyway.
fumb
Re: throttle cable
Probably ok on a track bike with plenty of run-off and cat litter. One the road if the cable breaks it could be a different story.tanuki wrote:Me neither I run a propper 1/5th turn HRC single cable throttle on the RVF and a NSR 250 (giving 1/5th turn) on the CBR track bike.mick.mh2racing wrote:Never understood why you need a cable to close the throttle. It's spring loaded so closes anyway.
