wanted ...
tractor664
wanted ...
hi guys seems to be all honda bits on for sale list ....i own a gk73a and need to find /buy 1 carb body so have any of you got an old set that i could buy jets etc not needed just body and mixture screw that moves ......if their out there they,ll be in the old suitcase at the back of the shed
- Variablevalves suck
Re: wanted ...
No Carbs but ive seen this a couple of times and always got the screw out. I get a good quality penetrating oil, wd40's not up to the job, turn the carbs upside down and soak the screw over nite. Then get a hex bit screwdriver and a small hex extension,find a bit that is a really good fit and push down on the screwdriver while turning the hex extension with a small spanner. You have to keep turning 1/4 of a turn and then back, then another 1/4 until its out.
- Awynn
- Bike owned: GK73a, CB250, NS125R-K, CLR125
Re: wanted ...
I bought a set of butchered carbs for a couple of spare parts so I have the bodies. Which body is it you need because they are slightly different depending where in the bank they are?(blocked fuelways on the end ones, an extra casting on one of the centres for the throttle cable etc etc) Don't get your hopes up too much until we figure out which you need because 1 or 2 of the bodies are butchered pretty well.
M1KE
Re: wanted ...
Got a full set of bandit ones have a look in the bandit section.
