nc29 front wheel help ?
on the fron wheel of my nc29 there are 2 spacers but one is wider than the other and i'm not sure which side the wider 1 goes on, can anyone help ?
Re: nc29 front wheel help ?
long spacer on right hand side
short spacer on left hand side
all as you sit on the bike facing forward
what i tent to do if i am using a paddock stand is to slid the spacers on to the relative sides petruding bar or sit then under the bike on the sides they come from.
you cang go wrong with the spacers if you try to fit them on the wrong side the disc will be tight up against the fork leg.
