Water leaking past fuel cap?
				benny1380
Hi, i had a problem with my fuel cap, when it rained heavily or when i washed the bike, water got past the fuel cap and i could see it in the little gully around the neck of the tank.  This must have got into the fuel, and the bike ran rough for a bit till it cleared out.  It was a fake carbon fibre cap that came with the bike, so i bought a proper second hand honda one, and it still does it!
Anyone else have this problem? What can be done>
				Gazzahh
 - Bike owned: NC30 MV F4 Kwak Z900
Re: Water leaking past fuel cap?
I thought  any water or spilt fuel drained away thro a pipe onto the top of the air box and down a rubber pipe? look under the tank for the drain hole.
				fastdruid
It's not designed to be totally water tight, only the actual filler hole in the middle is meant to be sealed and even then not totally. Water is pretty free to get into that 'gully' around the filler hole but there should be a drain hole in that 'gully'. If that drain gets blocked though water will hang around and then it might get into the fuel.
Normally either the drain tube gets blocked in the tank or the tube gets pinched. You didn't say which bike you have though as the drain routings are different on each.
I'd take a pipette[1] and pour a bit of water into the drain in that 'gully' if the water flows away all is fine, if it doesn't then pop the tank off and check all the tubing, maybe run a piece of wire through the drain hole in the 'gully'.
I've seen it on some where there would be a bit of water that would be in there on the stand but would drain once you got it upright.
Druid
[]1 Or similar, I just happen to have a load which are dead handy. :D
Druid
				benny1380
Thanks for the help, ill check out that drain hole and see how it goes.
Its a 1992 NC30 by the way, if it makes a difference?
				fastdruid
If you lift the fuel cap you'll see the drain hole on the far left (as you sit on the bike). It's quite hidden under the rim as normal. Not sure on the NC30 what the drain tube situation is like under the tank.benny1380 wrote:Thanks for the help, ill check out that drain hole and see how it goes.
Druid
				benny1380
Done It!
Cheers Druid, it was there and rusted over and filled with rubbish. poked it through and the water just drained out and no probs since!
