r6/r1 regulator mod on nc30
Dynamohum
Re: r6/r1 regulator mod on nc30
Post by Dynamohum »
shaun, i think that 13-14 volts is normal for a healthy charging system.
Cammo
Post by Cammo »
Neosophist wrote:Uninsulated spade connectors? :shock: Are you not worried they might touch? Or did you insulate them after that pic was taken!
No and no. They're such a tight fit that there's no chance of them budging, I wouldn't have used them if that was even a remote possibility.
It's a race bike, what can go wrong?! :whistle:
Post by Neosophist »
Haha.. I like your style
:peace: :smile:
Morespeedvicar
Post by Morespeedvicar »
Hiya, you have to have a source of more potential(voltage) thats higher than the battery so current will flow from the hi potential side(the genarator) into the battery to charge it. But the battery is only 12v as a nominal output voltage, i cant remember how to work out the specifics but you multiply the nominal voltage by so much percent and it takes it to about 13.2ish or something for true votlage reading.
You can charge a 12v lead acid battery upto about 15-18 volts depending on wat sort of battery you have and how much charge current the battery will take.
Hope it helps.
Ian
