Clutch basket problem
- One Hit Wonder
Hi
I've got a bit of a problem with my clutch which seems to like adjusting itself, I think I have traced the problem. When the clutch nut is tight the clutch housing has a fair amount of play in it, is this OK?
The clutch housing sits on the clutch outer guide via a bush, I assume this is what is causing the movement. Is it removeable or am I looking at a complete assembly?
