newbie with nc30 issues
mikevo
Re: newbie with nc30 issues
Post by mikevo » Mon Apr 27, 2009 10:51 pm
thanks for fast reply
so this will def fix the 6 k issue ?
what about the wont rev from idle ?
Cammo
Post by Cammo » Mon Apr 27, 2009 11:10 pm
mikevo wrote:thanks for fast reply
so this will def fix the 6 k issue ? Yes
Probably not.
mikevo
Post by mikevo » Mon Apr 27, 2009 11:16 pm
balls :cry:
will try this tomorrow fingers crossed
Post by CMSMJ1 » Tue Apr 28, 2009 10:03 am
Your 5.5k revs issue will go away..but the revving from idle..we can get to that!
Your idle screws set right?
mikevo
Post by mikevo » Tue Apr 28, 2009 10:17 am
hi done the 2.2k mod
but still wont rev from idle like you have said
idle screw is 2.5 turns out
any help gratefully excepted
Post by CMSMJ1 » Tue Apr 28, 2009 10:35 am
What does it idle at and what does it actually do, or not do, when you say it has problems from idle?
mikevo
Post by mikevo » Tue Apr 28, 2009 12:33 pm
hi
it idle's sub 1000rpm and you can hold full throttle and does not pick up at all now
one thing noticed was orange/blue was scotched locked to black/white with no resistor ,
its also fitted with m derestrictor and also speedo convertor(reduction gearbox) so some idiot have derestricted it 3 times
but all back to normal ie got rid of link wire (had tried resistor) and removed derestrictor box but left reduction gearbox on speedo
have 2 cdi one chinese one factory oe both do same (surely if cdi was goosed they wouldnt work at all ?)
could this issue be anything to do with pick up
all 4 cylinders get warm and all sparking healthy
even tried spraying carb cleaner into intake which had no affect apart from trying to stall it ,so i assume this counts out a fuel issue
:down: had enough really bike insured but cant ride and im itching too :cry:
Post by CMSMJ1 » Tue Apr 28, 2009 12:42 pm
Idle should be about 1300-1400 revs so get that screwed in and see how it goes . Sounds like it is bogging down?
What jets were in it when you sorted the carbs? Is the airbox standard and with the flap things at the front still there?
is your battery good?
You saying that if you blip the throttle is doesn't do much?
can you video it maybe? would make a lot more sense to see what it actually does?
mikevo
Post by mikevo » Tue Apr 28, 2009 12:50 pm
can remember what jet were in it pretty sure they are standard one bike is bog stock filter wise only a art can
battery good and charging ok when the revs get up a little
like said you can hold throttle wide open and will not rev over 1000rpm
can try and video
Post by CMSMJ1 » Tue Apr 28, 2009 1:01 pm
OK - so if you screw the idle adjuster in does it work?
got to be sortable...
