NC30 pre-load adjuster
shaun1988
Hi Guys,
Does any 1 know what the standard setting is for the pre-load to be set at on the front forks? what i mean is, if I was to turn the pre-load adjuster all the way in, how many turns out would I have to turn to have i at the standard setting
shaun
shaun
Re: NC30 pre-load adjuster
It depends how heavy you are.
As a rough start you would want to adjust it so you have about 25-30mm fork depression when you get on the bike.
shaun1988
Thanks for your reply, is there no "basic" setting for this the pre-load adjuster?
I was hoping some 1 to tell me to turn the adjuster all the way in and turn it 2 turns out or something like that lol
Benk
As stickshift has said, about an inch of static sag. If it was the same for all they wouldnt come with adjustment.shaun1988 wrote:Thanks for your reply, is there no "basic" setting for this the pre-load adjuster?
Im 100kg, and I had to increase the preload spacers (as they were full hard (clockwise ) previously), and drop the forks through the triple clamps a bit (10mm for me) to get things feeling better. Big thing is make a small adjustment, then try it. Repeat this till its all feeling good.
- Speedy
- Bike owned: RVF400RR, ER6n
Greggo posted a link in the 'General section' http://www.400greybike.info/newforum/vi ... =10&t=8785" onclick="window.open(this.href);return false; to a suspension setup guide recently! Have a look on here: http://www.crstuning.com/tuning_guide.htm" onclick="window.open(this.href);return false;
