Just bought a Nc23 Triarm for a winter project
Jakey Boy
Re: Just bought a Nc23 Triarm for a winter project
drifterwannab, as I think stimpy already mentioned, it's worth your while just giving Graeme France a call.
He'll sort you out with anything you need for a 23.
Regarding the 29 to 23 rear wheel conversion; this has little effect on the overall gearing, let alone speedo accuracy, assuming you use the standard size rear sprocket from the 29 which is smaller than the 23.
drifterwannab
Gullarm76 - yeah one of the down pipes had cracked away from the manifold plate and there a hole in the underside of the collector
I have just welded them up for now, will get a stainless at some point
Back end of the bike is all stripped off now and under going a pimp up
drifterwannab
just thought id give a little update.
I been pretty much skinted for a few months so not been able to buy any bits, so done some stuff that doesent really cost anything
First up lots of polishing hours, centers will be painted matt black
Just need to do the front one now
Also removed the subframe, sanblasted it and etched primed it ready for matt black top coat. Need to drop the engine out of the frame and i can set about painting it
Heres the bike at the mo
drifterwannab
Right decided to give it a service and put it back together and the 600rr conversion is on hold till winter.
Me and and me mate threw some paint on the farings, still need to get the side fairings sorted and gone put some stickers on to break it up a bit
Here it is
Here it is
