not for the faint hearted
- Bike owned: VTR-250, VFR400RR,
Re: not for the faint hearted
Jets are easy. Any motorcycle shop can get you those. The needles....now that's another story. Do they come with needles, as those are unobtanium in the taper/diameters they need.Smev wrote:I did a quick translation of the text and it said that they don't have jets in them as they are being used elsewhere.
But they are trick!!![]()
Cheers Smev
How's the copy of the HRC sets we have going? Anyone?
Mike Norman
I would have thought you could just order keihin needles from the catalogue to suit these bad boys Mike?g-force performance wrote: Jets are easy. Any motorcycle shop can get you those. The needles....now that's another story. Do they come with needles, as those are unobtanium in the taper/diameters they need.
Nearly all needle dimensions are available by the looks of it?
Hi Mike!
FCR setup slowly coming along. Lots of little bits and pieces to fabricate, though. While we're on the subject; do you have the lenght of the carb spigots (threaded "pipe' part connecting carb body and intake rubbers) measured from the actual carb body? I need to shorten the originals on my FCRs, but it's kind of a one-shot deal, too short and they're wasted.
Cheers/Lasse
Cheers/Lasse
- abrmoto
Yeah did the exchange after type that, if was about £750 as I had worked out then yeah would defo be interested, for race bike, but will just have to keep on using what I haveNeosophist wrote:£1300 quid serious?abrmoto wrote:Can anyone get them for me??
Serious!
Never seen flatslides for the NC, no wonder if they fetch that sort of cash!!!
Those are hot. I wonder how much lighter they must be than the stock items. Having had mine out enough times they weigh a ton :D
dosnt michaels carbon race bike have flat slides?
- mruehl34
Yep, i have a set of fcr´s. I got them in austria with papers from HRC and Moriwaki.Spike16 wrote:dosnt michaels carbon race bike have flat slides?
But it is not easy to find the right setup.
Michael
- fourfingers
- Bike owned: NC30RK,NC35RR
Well, Here´s next winters project. After looking at Her Ruehl´s pics , I don´t think I am going to get away just machining some spacers, but anyway, I hope it´s worth the try. For the rest of the mortals (that is excluding michael) fcrs from a fzr600 with yzf600 heads
. They will be here in a couple of weeks, and lets hope they are 32mm.
Michael, could you please help me out with the measures of the brackets and spacers?
And, how the hell do you get hold of all your stuff???
Maybe?
http://www.keihin-us.com/fcr.htm" onclick="window.open(this.href);return false;
Size / Application chart above...
FZR400 32mm D
FZR600 32mm D
YZR600 33mm D
35mm D
FZR750 37mm D
FZR750R 39mm D
YZF750 39mm D
FZR400 32mm D
FZR600 32mm D
YZR600 33mm D
35mm D
FZR750 37mm D
FZR750R 39mm D
YZF750 39mm D
