76 Carb hoses-fuel tap,which one goes where? 'On' or 'Pri'
				arkell
GK76A carbs, back on the bike, got a fuel line on the left and right of the carbs, which one goes to the 'pri' setting and which goes to the 'on' setting?
Bike is back together now just need to get it running!
				timoth123
Re: 76 Carb hoses-fuel tap,which one goes where? 'On' or 'Pri'
if they are standard hoses they should lie in the right position. but it doesnt matter either way, they both feed fuel at the same time. im guessin you got the vacuum hose on aswell?
				arkell
yeah the vacuum hose in on there as well, where does that go to incidently?!
				Gavsta
http://gavsta.blogspot.com/2009/01/fuel.html" onclick="window.open(this.href);return false;
Should tell you all!
Gavin.
Gavin.
