nc24 rear axle removal please help i'm going nuts!!
lilp4130
i have the whole rear end off the bike,
and the wheel and caliper off the swingarm but i cant
for the life of me get the axle out of the hub
i can even get the hub out of the swingarm no problem,
just the axle wont budge whats the catch please help!
der~kire
- Bike owned: nc24
Re: nc24 rear axle removal please help i'm going nuts!!
there was a small post on it recently.
2 there is a wire c shaped spring clip on the axle, chrome to, that holds the axle in the hub, that should help firstly.
3 uce a peice of metal plate or paint scraper to lever apart the twqo bolt clamp on the end of the swingarm, after removing the bolts, to release the hub on axle as a unit.
then you should be able to replace the bearings ect !
lilp4130
thanks for the reply man,
i have the circlip round the outside of the bearing off
but the axle still wont move,am i missing another circlip or some thing?
Heres a picture I took of the parts book.. it should help you see how its assembled.
It could be siezed.
It could be siezed.
lilp4130
cheers lad!
i'll have a go at it again tomorrow!
christ044
- Bike owned: NC24
I had the same problem,
Take the rear sprocket and carrier off, under this will be a washer, remove that, under that there will be a shaped spacer, this should just slide off, when you have that off look at the shaft just above the bearing (mine was covered in grease and very very hard to see) but there will be a small wire clip, if you use a small screwdriver you will find the end to it and pop it out. After that the shaft just slides out.
lilp4130
cheers mate you saved me some serious heartache there!!!
it was driving me crazy!!!
Part numbers 24 (small circlip) and 7 (collar) in picture above.christ044 wrote:I had the same problem,
The user 'carcass' had the same problem last year.. it must not be very obvious from that parts book picture?
Anyway, for anyone else reading this in future reference.
http://i46.photobucket.com/albums/f115/ ... G_1103.jpg" onclick="window.open(this.href);return false;
Thats the picture carcass took of the shaft after removing the cushdrive unit.
You can see part number 7 (collar) from the picture I posted above on the middle of the shaft.. slide this off the shaft and part number 24 (small circlip) is undeneath.
Like christ044 says, its prob greased over, hard to see, but a small screwdriver will get it off, then providing you've taken the rear brake caliper off / moved it out the way, the shaft will slide out of the hub.
Carcass
- Bike owned: Srad750, Nc29
Ah its all coming back to me, the NIGHTMARE of trying to solve that out! even the local garages were stumped!Neosophist wrote:Part numbers 24 (small circlip) and 7 (collar) in picture above.christ044 wrote:I had the same problem,
I was quite shocked when i saw how small the circlip was.
