BACK FIRING AND BLACK SMOKE!! :(
Re: BACK FIRING AND BLACK SMOKE!! :(
Yamaha reg recs are actually quite reliable ... I think this is the second one I've heard of on the forum. Different to honda ones which are rubbish ... people make such a fuss over honda but you'd have thought they'd have got a calculator out and added that one up right.
						- Motorcycle Solutions
- Bike owned: Kawasaki ZX9R E1
 Cheap, that old bird is back again
 Cheap, that old bird is back againO.K genuin ones around £45 plus vat
I can supply second hand one for just postage as in previous message or New After Market for grey bike boys at £29.50 posted includes vat...
				fzrtim
- Bike owned: FZR400 FZRhybrid FZR600 RSV1k
I've had 2 Yamaha reg/rec burn out on me. First one was on my 600, it just started bellowing smoke. Then the 3tj i have just repaired (passed  MOT on sat) had a problem with the battery being drained over night which turned out to be the rec.
Maybe im just unlucky???
- w00dzy
ok, he bought a new reg/rec yesterday for £50 it is a original one by the looks of it.
Battery still dies out only when the lights are being used a fully charged battery seems to die in about 30mins of riding with lights on...
Alternator works fine giving around 49v from 3 tests.. which i think is about right?
Surely the reg/rec could not have burnt out already?
The bike currently has no indicators? would this have something to do with it as it has all the connections still but not plugged in...
Thanks for the offer of sending one over with the fins for a pint or postage mate.. Might have to take you up on it if this one doest work!
				wullvfr
- Bike owned: zx9r c1
thats about right...............it should be 50 volts but 49v will do.w00dzy wrote:Alternator works fine giving around 49v from 3 tests.. which i think is about right?
i had similar problems with my nc30,the battery would get charged so long as i didn't use my lights,but if i used the lights the battery would drain faster than it was getting charged.
my charge rate @5000rpm was maybe just over 13volts.
i tested my alternator and the output was 30 volts on all three and when removed it was badly burnt out.
what is the charge rate at the battery at 5000rpm without lights?
william
						- w00dzy
it doesnt charge at the battery at all...
				wullvfr
so you know voltage is getting to the reg rec from the alternator......w00dzy wrote:it doesnt charge at the battery at all...
and you have replaced the reg rec and still unsatisfactory results.........check the connections between reg/rec and battery,positive and negative wires etc.!!!!!
did you test the alternator output at the connector that goes into the reg/rec?the reason i am asking is just so you know voltage is getting to the reg/rec.
william
						- w00dzy
 preparing to be flamed
 sorry for wasting your time peeps
 after trying yet another reg/rec which did not work.. we checked the fuse box... a 20amp fuse was literally melted to the box and yes it needed replacing! the battery charges fine now...
feel like an idiot hah...
my mate is pleased its running ok now and can run at night! however the bike is still backfiring with flames.. I guess this means that the fuel mixtures needs setting up.. At our local dyno in caterham called Carbontech they said it will cost about £50 an hour for them to tune it..
Is it easy enough to adjust this ourselves?
				wullvfr
 glad it's fixed now...that's the main thing!!!!
out of curiosity,what fuse was it?the reason i am asking is,i did not realise there was one for the charging system!!!!!
william
						- w00dzy
it was the one toward the rear of the bike on the end... if that helps... didnt notice if they were numbered..
