regulator Q
Spike16
regulator Q
Post by Spike16 »
ok im wiring on my new reg connector and and 2 of the yellow chargine wires had broken off
Does it matter what yellow wire goes onto what yellow connector wire (if that makes sence)?
Re: regulator Q
nope- but it does matter which ones the other 2 wires go into. Get it wrong and pop goes your fuse!
Spike16
Re: regulator Q
Post by Spike16 »
really great, no the other two are simple, mainsly because there GREEN and RED, pritty sure i can handle that
its just the three alternator ones are all yellow
wullvfr
Bike owned: zx9r c1
Re: regulator Q
Post by wullvfr »
Spike16 wrote:really great, no the other two are simple, mainsly because there GREEN and RED, pritty sure i can handle that
spot on spike....... ;)
william
Spike16
Re: regulator Q
Post by Spike16 »
well i only blew the fuse once, i accidently touched the red a green :? lol, couldnt believe the condition of the old connector il post some pictures up later but its a state
thanks to graeme france for the replacement, £8 for the plug bit of solder and a bit of heat shrink (although i used my own as it was the same colour at the wires) recomend checking yours as i had no clue mine was such a state
didnt fix my indicator problem but im getting it booked in at a bike electricians 2moro so hopefully by sunday it should be sorted, iv dont everything i can think of to fix it (bar replace switchgear) so its the turn of the pro's now
