deristricted CDI
				drifterwannab
deristricted CDI
Hello all
Am i right thinking this is a deristicted CDI?
- leopard_pagan
 - Bike owned: used to have a NC29
Re: deristricted CDI
what bike would it be for?
				stimpy
its for a nc23...gold label cdi means derestricted
rrj
stimpy
						rrj
stimpy
				LozVTR
Ive got a gold label CDI also...
is there anything else I need to do with the bike to ensure its fully powered?
Is the 112mph speed restriction taken out by the gold CDI or do I need to do other mods?
thanks
Loz
thanks
Loz
				sh4d0w0lf
 - Bike owned: VFR400R NC24, GPZ600R
the gold label cdi by itself means that the bike is de restricted! you will most likely find that ure bike is an NC23-RRJ whereas my bike has a blue cdi which means that it is restricted also meaning that my bike is an NC23-RRK, you'll be able to go faster than 112mph without mods whereas i need to mod my bike!
hope that helps
Adam.
						hope that helps
Adam.
- leopard_pagan
NC23-RR-J to 112mph de-restrict you need a gold label CDI pictured above.
NC23-RR-K to 112mph de-restrict you need the resistor mod
NC29-all models to 112mph de-restrict you need res mod...
all of the above can also be de-restricted by fitting a KPH to MPH manual speedo converter ONLY if your speedo face is still in KPH. this mod does not work with MPH faces.
the 3rd de-limiter mod for NC23-RR-K and all NC29s is to remove the half moon shaped disk from inside the speedo. this is not a mod for mechanical beginners!
4th way: Unscrew your speedo cable...leopard_pagan wrote:NC23-RR-J to 112mph de-restrict you need a gold label CDI pictured above.
				stimpy
no other mods needed for the nc23rrk when u run the gold label cdi.
none,zero,zip
plug it in and go
job done
thanks for comming
dont forget to tip the waiters on the way out
stimpy
						none,zero,zip
plug it in and go
job done
thanks for comming
stimpy
- leopard_pagan
spot on stimpy.. but not everyone can get their hands on one.. so there are a few other options to pick from.
				LozVTR
nice one....thanks all
especially stimpy, I think you answered that one very well.
