Moriwaki twin stack end cans
tom wood
Post by tom wood »
Hi everyone.
On a twinstack exhaust should the bore of the cans be the same bore as the pipework? The pipework that I have is 1 1/2 inches diameter.
I've just had a bloke make me some straight through cans up and they are 1 1/2 inch inlet and 2 inch bore through the silencer. Is this right?
Has anyone else had some new cans for a moriwaki system made up? Any chance of the dimensions?
viper_biker
Re: Moriwaki twin stack end cans
Post by viper_biker »
Hi Tom, I got your PM, but haven't had the chance to reply yetm but here's the measurements of my cans,
Inlet - 38mm
Outlet - 44mm
Slieve bore - 85mm
Slieve length - 395mm
The perforated tube goes on the outside of the inlet pipe and is on the inside of the outlet pipe, if you get what I mean. If you are not happy with them then I'd be straight back asking for them to be corrected.
tom wood
Post by tom wood »
thanks for getting me the measurements. im going to get them sorted
tom wood
Post by tom wood »
did you have to get another can strap? did you get it with the cans? just benn looking and its quite a big difference between the moriwaki cans and the ones i've got made up
viper_biker
I got the Mori strap with the system and it fitted the new cans perfectly
Old cans,
New cans,
royster81
Post by royster81 »
tom wood wrote:did you have to get another can strap? did you get it with the cans? just benn looking and its quite a big difference between the moriwaki cans and the ones i've got made up
mercury made a really nice can strap but getting the hold of them is hard work atm ...
Cammo
Post by Cammo »
viper_biker wrote:I got the Mori strap with the system and it fitted the new cans perfectly
Porn! 8-)
i've never had twin stacks, it's on my list of things to do before i die!
tom wood
Post by tom wood »
the strap fits around the bottom can ok. But when I try to put it around the top I end up with gap of about 6mm where the 2 ends should clamp together.
tom wood
Post by tom wood »
do you have the tabs of the can strap either side of the exhaust hanger or both on one side?
