Getting nc30 carbs back in insulator rubbers
Kenthammer
Bike owned: 92 NC30 & 94 CBR900RRR
Re: Getting nc30 carbs back in insulator rubbers
Post by Kenthammer »
Yep guess measuring them is gonna work. 😂
eeriedess
Re: NC30 insulator rubbers install FIT ON CARBS OR FIT ON INLET STUBS
Post by eeriedess »
Hi fellas yes you have seen a similar post from me a long time ago but I still have an issue fitting these insulator rubbers and the HAYNES MANUAL IS NO HELP!!!.CAN THE CARBS BE PUT BACK ON WITH THE INSULATORS FITTED TO THE CARBS OR DO THEY HAVE TO BE FITTED TO THE INLET STUBS?? And what is the best lubricant to assist the instal that won’t affect the material.
I’m now 79 yrs young and have no one to assist fitting also recently diagnosed with Motor NeuroneDisease so my strength is evaporating day by day and by god come hell or high water I will get to ride this beast before my name moves to the top line of the Ledger.
It’s a nightmare job to do AND I JUST NEED THE EASIEST WAY TO INSTAL CARBS AFTER ATTEMPTING TO FIT A NEW SET YESTERDAY ONLY TO FIND ONE OFTHEM SLIP IN HALF.
HEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEELP
COLE
MadMotoUK
Post by MadMotoUK »
Easiest way is to warm them up in hot water then fit them to the inlets. Push the front carbs in and there should be enough flex to rock the rear bank into place.
^^ exactly that ^^
Get them onto the engine first and get the lower clamps nipped up - put the top clamps on and loose enough.
If youhave it, a small smear of red rubber grease to allow for an easy insertion
Get the front carbs lined up, nice and level. you'll be wanting a glamorous assistant to help you line up the rears and check you don't fold the lip over as you push the fronts in and towards the front of the bike - they'll go in easy with a nice pop - and you then need to push hard and down to get the rears in.
Be glad you checked the throttle cables and choke were still attached :) Nip up the clamps - make sure the carbs are in before you do them. they go in with an obvious feeling.
eeriedess
Post by eeriedess »
well since my last post i have had the carb set off another 2 times!!!! this due to engine not starting. after cleaning the carb set AGAIN(ultrasonically) and wrestling them back on the nsr insulator(new) had the lip split off so another new set (ebay) fitted to the inlet stubs and the wrestling match started allover again.this time no splits BUT AGAIN NO START !!
SO I DRIBBLE FUEL IN THE OPEN CARB MOUTHS HIT THE STARTER AND IT FIRES UP AND DIES AGAIN.OBVIOUSLY ITS ONLY STARTING ON THE SMALL AMOUNTS POURED INTO THE CARB MOUTHS.
work done:--
jets floats needles and pins ULTRASONIC CLEANED AND ALL CLEAR
REMOVED -throttle slide assys Durex no holes
New coils and ht leads and plug caps
Replacement used generator coils(ebay) still only reading 300 ohms same as removed (manual says 450--500 !!)
Checked reading on TCI unit AOK
COMPLETE VALVE SHIM CHECK PLUS REPLACEMENTS---- (DONT GO THERE UNLESS YOU WANT TO LOSE YOUR SANITY OR THE ENGINE IS OUT OF FRAME!!)
NEW SPARK PLUGS NGK
REMOVED STARTER MOTOR CLEANED COMM AND REPLACED BRUSHES WITH NEW
NEW BATTERY(STILL CRANKS TOO SLOW FOR MY LIKING)
CLEANED EARTH LEAD ATTACHMENT NS FRONT OF FRAME
COMPRESSION TEST.
Have i missed something out not done ? almost ready to give up. ANY IDEAS ??
magg
Bike owned: VFR400
Post by magg »
Fuel tap flows when vacuum applied?
eeriedess
Post by eeriedess »
hi Maggs thanks for the only reply so far but yes i am using a remote fuel feed so its even more frustrating with no fuel getting to the engine. im going to take compression tests again this afternoon but im running out of ideas oh and i have tested the voltage to the coils and they are both reading 12volts
but im still not getting a"fat blue spark"on a spark plug ?
magg
Bike owned: VFR400
Post by magg »
A couple of quick comments while i contemplate your observations. Pulser coils are generally reliable items. My spare pulser coils measure 388 and 405 ohms at 10 degree centigrade. Temperature has a significant affect. 450-500 ohm figure is at 20 degrees and I would not use it as a pass/fail criteria. Do you have a timing light that you can attach while cranking the engine. If it fires when engine cranking it suggests you have a spark no matter what colour it is. You can also check that the ignition is firing iaw the timing marks. Put this post on the other post as well. Will comment on this post only in the future.
magg
Bike owned: VFR400
Post by magg »
Have you tried removing the float bowl fuel drain screws to confirm the the carbies are full of fuel.
eeriedess
Post by eeriedess »
HEY MAGG THAT WOULD BE A NEAT TRICK IF YOU COULD REMOVE THE FLOAT BOWL DRAIN SCREWS WITHOUT DRILLIN HOLES IN THE FRAME RAILS TO GET SCREWDRIVER ACCESS !!!!!
