Rs250 seat on nc30
Rs250 seat on nc30
Does anyone know what model rs250 seat fits the nc30? Aprilla, rsw250 etc.
I have a rs250 Honda seat resting on a custom sub frame but it needs so much modification i may as well go back to standard?
Muzz
Muzz
Re: Rs250 seat on nc30
the honda rs250 seat unit fits really easy.
it still uses the original mounts too.
all you need to do is cut a Y shape in the seat pad area. then stretch it open about 1 inch or so.
put a 1.5mm plate into the seat base for strength and then fibreglass over it.
it mounts directly onto the original nc30 mounting points
Would you know what year rs250? Thanks
1993 to around 2000 year fits very well
Thanks. Will give it a go. Turned out to be an expensive mistake
the custom subframe was expensive mistake?
