is this better cut in to two or better as it is stock?
So the local mechanic guy cut this hose that in on my NC23 carb, but all previous carbs I have had for this model have ad this pipe un-cut.
He said it was a breather pipe and should be like it is in the picture... but, I don't think he's right, as I'm sure Honda would have built it like that if that were the case.
should I get a male/male adapter to join them back together or is he right?
Why would someone cut this without checking?
Why do these carbs look like they haven't been in an ultrasonic bath?
All very good questions...
Re: is this better cut in to two or better as it is stock?
Local mechanic who knows better than the big H........
Says it all really.
Says it all really.
I'd want it to be as standard as possible - Are they not the fuel overflow pipes?
- Bike owned: 3 x NC35, 3x NC24, NC29, RC46
No he's not right but its not the end of the world.
If they thought it was clogged its easier than removing the carbs
Because they haven't..
You have discovered a lazy mechanic who isn't familiar / competant with older bikes
= Time to find another mechanic.
- Bike owned: NC29 CBR600F
And the winner is Suzuki416.Suzuki416 wrote: Wed Oct 27, 2021 9:34 am should I get a male/male adapter to join them back together or is he right?
I Don't think the mechanic you used was very good nor was he being honest about doing an ultrasonic clean properly. He may have put them in but didn't use the correct solution and did he take them apart to clean them
