I've got about 60hp on the dyno last summer.
At this moment I've bought NC36 engine and working on the turbo build.
But looks like covid-19 somehow suspended the process
Yes it was worth it as a fun project. New skills, new friends, new ideas.
More like 200%. The NC36 engine (which as I read the thread is the engine that's been modified) would only be 37BHP in standard form.
Yes, I do know how to spec them and that's the reason I chose 2530 over GT12-17 or IHI VQ50 (which I have on the shelf)MadMotoUK wrote: ↑Wed Feb 17, 2021 9:31 pmWithout wishing to offend, but do you know what you are doing with turbos? Have you any idea how to spec them?
I've just had a look at the specs for those turbos you've used as the numbers seemed familiar and rang alarm bells. They are way too large for the 400cc engine. The GT2860RS is designed for engines from 1400cc to 3000cc and 250-360 BHP. The HKS2530 (re-badged Garrett with different shells) was developed for the Skyline and aimed at the 500+ BHP mark.
No, it's not like that. You're taking into an account BHP but not engine working RPM ranges, expected spool time/zone etc.MadMotoUK wrote: ↑Wed Feb 17, 2021 9:31 pmYou'd be much better off using a Garrett GT1241 (good for up to 130BHP) with a 29mm intake, 41mm exhaust and a 35.5mm turbine. Expect a boost from 37BHP (NC36) to around 70-75BHP providing you've got the proper airflow and other engine mods properly done. It's not unknown to obtain around 90BHP but that involves a lot of £££ spent and it's pushing the engine to it's limits.
It's rather a rule of thumb than an actual rule. You want to stay away from pre-ignition, detonation and excessive gas pressure.MadMotoUK wrote: ↑Wed Feb 17, 2021 9:31 pmBear in mind that in order to fit a turbo to ANY engine, you have to lower compression (this has to be calculated properly) or the pistons will shit themselves and the engine will be destroyed. You also have to adjust the ignition advance and the timing. If you don't, expect very soon to have a rather large paperweight or door stop.
Yes, that's what makes it roadworthy and not a widow maker. You don't want to hit the boost in the middle of the turn when you're tilting and expecting full throttle control and no sudden things.
