Nc30 Sump Removal Exhaust off??
montsta56
Post by montsta56 »
Hi Guy's I'm in the process of replacing the sump on my race bike do I have to remove the front exhaust to be able remove the sump??
Looks like i wont be able to clear the oil pick up etc unless I remove the exhaust???
CHeers
viper_biker
Re: Nc30 Sump Removal Exhaust off??
Post by viper_biker »
Yes, you will need to remove the headers to get the sump out. Bit of a pain, but well worth it (and maybe a fluid change for the rads too ;) )
oliherst
Post by oliherst »
Yes you have to remove them, I did this earlier this year, basically after an oil change I cracked the sump doing up the sump plug (don't ask). Then snapped off a stud trying to remove the front down pipes, then had to replace the exhaust clamps lol, all turned out to be an expensive oil change :shock:
hannakournikova
Bike owned: NC30, NC35 & SP2
Post by hannakournikova »
oliherst wrote:Yes you have to remove them, I did this earlier this year, basically after an oil change I cracked the sump doing up the sump plug (don't ask). Then snapped off a stud trying to remove the front down pipes, then had to replace the exhaust clamps lol, all turned out to be an expensive oil change :shock:
moral of the story...never change your oil! :oops:
montsta56
Post by montsta56 »
Oh Hell Thats how I cracked my sump :oops: Best I get the WD40 out so I dont snap off the header stud.
Thanks for all the help guys
dx400r
Post by dx400r »
You can cheat a little by slackening the header bolts and the link pipes then pulling them forward a little - then if you can manage to gett the biggest of the fins past the two pipes under it you can get the sump out.
Well... if you have the time. Make it easy and do it the normal way. If you were like me and had limited time and had just dropped a shim into the engine :o :cry: and had a theory you would find it in the bottom of the sump - which I did 8-) along with a zip tie :?
