nc30 nc35 tank holes distance.
I need to cut the rear frame on my vf400f to fit the self made aluminum frame build with a shape similar to the Cagiva Mito's one, so I'm wondering what's the hole to hole distance of the nc30 and nc 35 tanks. I guess nc35 is a little bit shorter, but confirmation and lenghts would be highly appreciated.
Re: nc30 nc35 tank holes distance.
No one have any measure?
At this stage (considering I have to cut away the vf rear frame around 3 kgs and the Mito rear frame 3,5 kgs to swap with the aluminum Mito 1,5kg) I'm at 138,5 (68,4 rear 70,1 front kgs). Add the fairing, tank, carbon silencer, and gsxr k7 flywheel and I'm figuring going to 149 kgs. Not that bad.
- Bike owned: 3 x NC35, 3x NC24, NC29, RC46
What measurement do you need for the NC35
Hi, I need the distance centre hole to centre hole of the attachements of the tank to the frame. Just to know if fits better the mc35 or nc30 tank
Ok I have a NC35 tank off the bike - can measure whatever you like? exactly what do you need? The width dimensions of the tank from hole to hole ..?
tank from hole to hole, Thank you.
