NC30 fork strip
socket13
- Bike owned: Honda SP1, BSA Golden Flash, H
NC30 fork strip
Stripped the forks,stanchions away for rechroming , the Haynes manual says when you start the rebuild ,you insert the damper rod minus its components and fit the Allen bolt into the damper rod and tighten to specified torque, as I didn’t need to replace any of the components on the damper rod, can I just refit it complete as it came out of the fork tubes?
