NC30 hard to get neutral
Lewis34
Post by Lewis34 »
Does anybody else find it difficult to select neutral when the engine running? Seems fine with the engine not running
richyrd5
Regular Member
Re: NC30 hard to get neutral
Post by richyrd5 »
It helps if clutch is adjusted perfect but is a known trait on these...also make sure whatever is properly lubed and adjusted
Vincent
Bike owned: '89 NC30 T1, '92 NC30 T8
Post by Vincent »
Just blip the throttle a little and then try for neutral. Should slide right in.
moforockband
Bike owned: GK73a SP CRM250 mk3
Post by moforockband »
It can be because the clutch is not slipping allowing the gear to be selected easily. This can be due to wear/distortion in the clutch or bad oil
Lewis34
Post by Lewis34 »
Cheers lads
