RVF400 NC35 ongoing problem
Travis
Post by Travis » Fri May 17, 2019 2:00 pm
Hello,
I need some advise please. I have a RVF 400 that I have built up from a junkyard project.
I cannot get this thing to start.
Some background:
  • New Plugs
    Freshly rebuilt carbs - bench tested float valves, all working as they should
    Standard exhaust and intake, and standard carb jetting
    Checked compression - its good
    Check spark and there is spark - i remove the plug and leave it on the wire, it sparks when against the frame
It will NOT fire up, it will just turn and turn and turn and make ZERO attempt to start.
I confirmed via drain screw that the carbs are getting fuel (all 4 of them).
All I can think to do is check ignition timing is correct?
Any advise, this is a two year long project, and the bike looks spectacular, I just cant get it to fire up.
Thanks!!!
Speedy
Bike owned: RVF400RR, ER6n
Re: RVF400 NC35 ongoing problem
Post by Speedy » Fri May 17, 2019 2:20 pm
Sounds like something is cutting off the ignition.
Check switch connections are as they should be; side stand and/or kill switch?
Travis
Post by Travis » Fri May 17, 2019 2:31 pm
Side stand and kill switch would cut spark, I have spark though? just no ignition which is driving me mad.
Suzuki416
Bike owned: 3 x NC35, 3x NC24, NC29, RC46
Post by Suzuki416 » Fri May 17, 2019 6:25 pm
are you pulling in the clutch & is it in neutral?
Travis
Post by Travis » Mon May 20, 2019 12:32 pm
Hi, thanks, yes I am,these things would cause the system to cut spark, the bike has spark albeit a weak looking little spark.
If I pull a plug wire and put a plug on it, against the frame, it sparks.
I have spark, have fuel, I have compression, it just doesnt go boom
gavins
Bike owned: NC30, ER6f, K5 750
Post by gavins » Mon May 20, 2019 1:33 pm
What's your battery voltage look like? Try another battery or better yet jump it off a car battery?
Have the valve clearances been checked?
Travis
Post by Travis » Mon May 20, 2019 2:09 pm
battery about 18 months old, fully charged though overnight before I tried to start it the last time, the motor turns happily on the starter for quite a while before it gets run down. clearances are set within spec by myself
Speedy
Post by Speedy » Tue May 21, 2019 2:26 pm
The kill switch kills the ignition; I believe the side stand switch does the same.
When the kill switch is on the 'Off' position, the starter motor will still work, but the engine won't fire up.
I'm assuming you have the kill switch on the 'Run' position, (you wouldn't be the first ;) ) so maybe check the wiring, connector and the switch itself too; it's worth checking the clutch switch as well.
batchelor
Post by batchelor » Tue May 21, 2019 7:47 pm
Did you fit new plugs?
I had a problem on my NC30 where it would only fire on 1 or 2.
All plugs sparked when checked against frame.
Turns out the plugs were weak. New set fitted problem solved.
Plugs are not cheap and watch out for fake ones on ebay.
Travis
Post by Travis » Wed May 22, 2019 11:20 am
This is my last resort, these dam plugs cost a fortune, ZAR1000 for a set of 4. Im tempted to take the known working plugs out of my VFR and stick them in the RVF and see if it changes things? its good to know you tested them and they sparked, as mine also do, but then when you used new ones it worked. perhaps the plugs are fouled and dont spark enough? I always thought that spark is spark, perhaps it needs a really strong spark to ignite. thanks :)
