Cam gear drive
freeserve
Bike owned: vfr400 nc30
Cam gear drive
Post by freeserve »
Hello,
Which way round does the cam gear assembly go? On the bottom small gear which is split does the split section mesh with the gears below or does it face away from the gear, the manual suggests there are identification marks under the flange but I can not find it.
Many thanks.
Re: Cam gear drive
Are you looking at Haynes or the Service Manual?
They have an F and R marking and the bolt that secures them faces the insides of the V
Re: Cam gear drive
Just looked at the manual
"When the mark is not clear the gear case can be ID'd by the sub gear of the second gear. With the sub gear toward you;
for front cylinder> the sub gear is off to the left side from the main gear
for rear cylinder> the sub gear is off to the right side from the main gear."
http://www.400greybike.com/docs
go get the service manual :)
freeserve
Re: Cam gear drive
Post by freeserve »
Thanks very much, will check out this weekend.
