Valve Clearance Guide
Re: Valve Clearance Guide
Thanks for the reply.
I now wish i had a big bag of shims!
to confirm ref 2 - are we all as happy as we can be i havent trashed anything. The other post seemed to imply it was the end of the world as we know it.
Adam
Adam
It's taken me 15 years to get these shims.. :)
I reckon you'll be fine - the turning it over and the finger getting a bit stuck on the collet is not great, but I cannot see if breaking anything.
get it back and measured up and see what goes on for your gaps.
If you find you need some specific sizes and are stuck - I'll swap some with you
Thanks - I did have a list of 5 shims I needed, but those are irrelevant now as I measured the wrong gap!
Re the turning the engine over - that was my thinking - shouldn't have done it, however nothing should really be damaged and all I need to do now, is put all 16 shims back in and start again
Started checking my clearances today, taking my time and taking a long time.
When replacing the shim, after measuring, I found that zip tying the cam follower to the opposite cam bearing tower held the follower out of the way, so I had two hands to reinstall the shim.
Just my 2c.
Regards,
Tony
Just my 2c.
Regards,
Tony
