RRJ speed restrictor
Hi all
Can someone tell me definatively if there is a speed limiter on the j series and if so what to do please
Nc23 rrj
Gold ky2 cdi
Speedo removed
Rev counter working
Not sure if cdi is failing, been on dyno amd power nose dives at 12200-13000 then it picks up again, dyno fella said he has never seen anything like it but believes its electrical almost like an electrical limiter. You can see dyno. Chart fromy link
https://drive.google.com/open?id=1dcfVs ... lJPN0m2bKL
Thanks for help in advance
Nc23 rrj
Gold ky2 cdi
Speedo removed
Rev counter working
- Bike owned: NC29 Race
Re: RRJ speed restrictor
There is no speed limiter on the RRJ it was the later RRK model that cane with the blue CDI that has the restrictor the RRJ which came with the gold is unrestricted so the fact you have the gold CDI regardless of which model the bike is rules out the speed limiter,
What's the background of the bike, you say speedo removed is this a track/race bike?
What work has been done if any?
How long have you owned the bike?
Is this a problem that has just developed or did the bike come like this etc?
Might help us pin point the route of the issue, Being a Dyno operator myself for years 90% of the diagnosis is in the back story, but I looks to me like some sort of electrical misfire possibly dropping two cylinders (explains why you think it could be speed limiter related) if you can figure out which cylinders are dropping obviously it makes it easier to diagnose.
Let us know how you get on
Si
Si
Thanks for the reply and the interest, it is track bike. 112 dynojet, spongy air filter, ram fairing pipes on place, idle screws 2.5turns out, carbs cleaned and floats checked again and diaframs, I have used this bike. Only on the track for 16yrs,,std headers Hyde race can. 14/42final drive, using shell v power fuel but been told by Graeme to go back to good quality unleaded. Always had a flat spot or misfire but moves around the Rev position each year. Before it’s been 8k, 10k now 12.5k
New plugs, cleaned out plug caps and resistors,can my cdi cause this problem??
One last thing last year it seemed ok on the 14/40 bit now on the 14/42 it is so noticeable, coincidence or lower gearing made problem noticeable?
Doe sit always nose dive at exactly the same revs all the time or just happened on that run? Your bike should be ok on supermarket fuel, no need for fancy stuff.
I'd install a new pulse coil, as they give the symptoms you have and can break down when hot.
It now pulls up at the same Rev, however for the first 3/4 Laps it is perfect. Tested pulse coils as best as possible with ohm meter to book spec, all ok and ac voltages from system before regulator/ rectifier.
I had something similar and then the bike would just cut out. It was caused by a dry joint or one of the components in the CDI getting hot and breaking down. Really frustrating to find as by the time you had pushed the bike back to the pits, everything had cooled down and the bike ran fine again
Fitted a replacement CDI & it was all good. Probably not what you wanted to hear but we are talking about 30 year old electrical components.
All ideas are considered, I am now more and more heading the cdi route after nearly everything tested and replaced. Thanks M8
