NC23 speedo not working - new cable fitted
Madbikerbird
One Hit Wonder
Post by Madbikerbird »
Cn anyone help? I have fitted a new cable and my speedo is still not working! Please help a damsel in distress!!!! :grin:
dunkenb
Regular Member
Post by dunkenb »
It’s probably the little plastic bit that fits over the sprocket nut to drive the cable. They can round off.
Pull the sprocket cover off and have a look. You can get new ones from Graeme France or David Silver.
Also lube the mechanism the cable goes into on the sprocket cover[emoji41]ImageImage
Maelstrom
Bike owned: MC22, 3TJ1
Re: NC23 speedo not working - new cable fitted
Post by Maelstrom »
The inner cable rotates as the rear wheel turns.
Support the back of the bike on a stand.
Disconnect the cable from the speedo.
Rotate the rear wheel.
If the inner cable is rotating you have a speedo problem.
If the inner cable is not rotating you have a drive problem, see previous post.
Carb seal kits in viton & other parts
https://litetek.co
