Fast Forward to December 2016 and some 7000kms later....
The bike had a oil leak when every time I parked it
Also the head lights started to work intermittently
Finally the battery just would not hold charge.
I started to investigate the oil leak, turns out the oil filter had worked itself loose just enough to leak between the engine and the filter.
I opened up the wiring loom for the charging system and was met with this un-holy sight...
After putting some new connectors in, wow battery is charging again.
The headlights remained a mystery as I was convinced the relay was the culprit...
I one day removed the tank and traced the wiring and plugs etc, I found the 2 plugs in the main loom under the carbs to be at fault, I cable tied it and the connection was not intermittent anymore.
