Well I'm definitely purchasing this. Can't ask for a simpler solution. Just makes me wonder what is different now than when it rolled off the showroom. Why did it start then and not now? Loss of compression? Bad electrical connections?SevenThreeSeven wrote:I modified my B4, that's how I dealt with the DOT stupidity.
I searched around and found FastEddy Sports in the U.K., they have produced a plug-n-play modification that keeps the headlight off when you key-switch the bike to "ON". The headlight stays off while you start up the bike and then when you want the headlight to come on you flip the headlight switch to High-beam then back to Low-Beam. After that the headlight will operate normally, low-beam and high-beam.
It works with the B4 because it's designed to work with an H4 Headlight bulb, which the B4 uses. The FastEddy Sports people originally developed this modification for the early fuel injected Triumph motorcycles which were very hard to start due to battery draw.
https://www.fasteddysports.com/products ... uct_id=882
