GK73/78 compatibility
				chrisk8226
A long shot, but does anyone know if the valves from a GK78 (RF400 1992) are the same as the ones in a GK73 i.e. 81mm length, inlet 20mm ex 22mm? I have access to some new ones but need to know they fit!
						- Variablevalves suck
Re: GK73/78 compatibility
Sorry can't give you a definite but I believe the rf used the bandit motor.
Like I say don't take this as correct.
It was produced from 93 so will be a 53 hp engine and from about 96 was vvc only that used a shim style valve adjustment.
Can you not get a part number from the supplier, simple Google check then.
				chrisk8226
Cheers, thanks mate. I suspect they are the same but these are an aftermarket valve out of China so no part #'s to match up with   . A couple of the racers here have been using the Chinese ones in their Honda and Yamaha historic race bikes with good results and they are about 1/8th the cost of the genuine article!
 . A couple of the racers here have been using the Chinese ones in their Honda and Yamaha historic race bikes with good results and they are about 1/8th the cost of the genuine article!-
				ventYl
- Bike owned: GSF 400 Bandit
RF400 is RF600 frame adapted to host Bandit 400 internals
