NC30/35 Engine Bearings
- Tim400GB
Re: NC30/35 Engine Bearings
You've got my interest.
What consists of a 'set', 4 of each size?
				duke748bp
 - Bike owned: Ducati 748, VF400, NC30
Curious...Not that I'm in a need or position to do so ( having just got the bike ) but are many essentials such as these ( and your similar piston buy) going no longer in stock making simple rebuilds no longer an option?
						- JC120
 - Bike owned: NC30 NC35 RC30 RC45 MC22 NXA
It's not possible to do a 100% quality rebuild without these parts. If the bearings are worn, than they need to be replaced before it fails.
							V4ia addict
						- Yakama
duke748bp wrote:Curious...Not that I'm in a need or position to do so ( having just got the bike ) but are many essentials such as these ( and your similar piston buy) going no longer in stock making simple rebuilds no longer an option?
Yes Honda have discontinued the bearings and Pistons now, though you can still get rings
				thenewwazoo
 - Bike owned: RC79 / RC46 / NC35
I really should check this forum more often.
I'm in for a set at any price, Mike. I'll even swing by on the RVF when I pick 'em up. :)
- Variablevalves suck
Can you post up the bearing sizes.
Ive a mate who runs a bearing supply company and another who runs a gear company, I will ask if they know anyone that manufactures custom shells.
				g-force performance
 - Bike owned: VTR-250, VFR400RR,
Re: NC30/35 Engine Bearings (New Bearings On Order)
Hay All!
I have great news for those looking for bearings. I have just struck a deal with Daido Metal USA, Performance Bearing Division, to make replacement bearings for the NCs. Daido Metal in Japan is the OEM for the Honda bearings.
For more information, please see my blog here: http://mngforce.typepad.com/nc450vdev/
Mike Norman
G-Force Engine Development
www.mngforce.com
There is no such thing as "Too Fast"
Mike Norman
www.mngforce.com
- jpete41996
 - Bike owned: VFR 400
This might be off subject, but is there a way to tell what bearing color is used without taking it apart?  Something tells me "no".
Sent from my iPad using Tapatalk
If i can wrench on cars, bikes should not be a problem, right?...
				g-force performance
If you look at your case codes, and can see your crankshaft through the little view windows behind the alternator, sometimes you can get the crank codes. Then, you can tell what Main Bearings you have, and a ball park of what the rod bearings might be (since you can't see the rods - unless you flip the engine over and pull the oil pan)jpete41996 wrote:This might be off subject, but is there a way to tell what bearing color is used without taking it apart? Something tells me "no".
Or, for less than $30, you can buy a great USB Borescope "Snake Light" from China. I was so impressed that I bought two of them. Be sure to get the 5.5mm dia head so you can go through the spark plug hole of these babies.
http://www.ebay.com/itm/1-5M-5-5mm-6LED ... Sw8w1X2QZI
Otherwise....."No"!
Mike Norman
www.mngforce.com
- jpete41996
Thanks mike!!
