NC30 1mm Neelle Shimms (Washers)
- Bike owned: NC30 Grey Import
Hi Guys, am thinking of doing the mod to improve the flat spot on the NC30. Rick Oliver suggests a 1mm thick washer. However what sort of inside and outside diameter's am I looking for?
Suggestions on a post card as usual.
Thanks guys
Thanks guys
- Bike owned: RVF400
Re: NC30 1mm Neelle Shimms (Washers)
From a stock nc35 washer - 12mm outer diameter and roughly 4mm inner diameter.
Ricks washers are pretty spot on and fairly cheap..
- Bike owned: NC35, 5SL, 3XV, 2MA
A plain old 4mm washer is the right size and half millimetre thick - two per needle is perfect.
Thanks guys.
I did look on Rick O's Stock sheet but he doesn't list them as individual items, just as part of kits, hence the question.
