Nc30 fairing on Nc24
ruankoekemoer001
Post by ruankoekemoer001 »
Hi. Is it easy to fit the vfr Nc30 fairings on a nc 24.
jim157
Admin NWAA
Admin NWAA
Bike owned: A few small ones
Re: Nc30 fairing on Nc24
Post by jim157 »
No, not without a lot of modifications.
AUTOEXEC.TWAT
Post by Neosophist »
as above.
no.
frame is a lot different, subframe is different. headlights are different
pretty much everything is different.
I wouldnt say its impossible to do anything but it would need a lot of modifications.
ruankoekemoer001
Could you mabey tell me witch fairing would fit on the nc24 (eg. Honda, kawasaki) i am looking to upgrade the look as my fairings are cracked and need replacing
ruankoekemoer001 wrote:Could you mabey tell me witch fairing would fit on the nc24 (eg. Honda, kawasaki) i am looking to upgrade the look as my fairings are cracked and need replacing
nothing apart from an nc24 fairing.
jim157
Admin NWAA
Admin NWAA
Post by jim157 »
Or an NC21. ;)
AUTOEXEC.TWAT
yeah good point, the nc21 front and sides are the same panels in a different colour.
the rear tail section will fit straight onto the subframe too but you will need to buy the seat as well as it uses a long dual seat rather than the 2 separate seats of the nc24
ruankoekemoer001
I would like to mount the nc30 rear fearing in my nc24. I am willing to do modifications. Could you give me some detail on how to modify
Morespeedvicar
Post by Morespeedvicar »
I think the only way your going to do it, its buy one and try it, you'll also need the headlights and make a support bracket too. Plus also the clip-ons may hit the fairing.
Be interesting to see it done.
Ian
if you have to ask how to do it then i think its probably beyond your ability.
The bikes while the engine are the same have totally different frames / forks and subframes.
what this means in simple terms is that there is a good chance the panels are either too large or too small, and they wont be wide enough or two wide.
Having owned and worked on both, the mounting points are all in totally different placees for the panels.
This means at the bare minimum you will have to make all new mounting brackets for the panels and spacers, the front cowel uses a different stay so you will need to nc30 clock bracket and mirror stay as well (mirrors are different spacing so will need the mirrors too as the nc24 ones wont fit the nc30 cowel)
nc24 clocks wont fit the nc30 mirror stay and nc30 clocks wont work with the nc30 loom so will have to be creative makigns omething there.
unless you are very skilled with metalwork and plastic work then you will most likely end up with somethign that is poorly fitting and looks a hack.
you can get aftermarket nc24 fairings from China cheap enough.
