NC30 how to determine original paint scheme
krisztian_andre
- Bike owned: MG v35 II, NC30, MG NF Mil.
Hello,
how can I tell which paint scheme was my nc30 originally?
- jim157
Re: NC30 how to determine original paint scheme
As far as I know the only way to tell is from the production sticker that is stuck on the top of the undertray. If this is missing I dont think there's any way of finding out exactly which scheme your bike was but the V-source site has a table that narrows down the possibilities dependent on chassis and engine numbers.
AUTOEXEC.TWAT
krisztian_andre
Hi,jim157 wrote:As far as I know the only way to tell is from the production sticker that is stuck on the top of the undertray. If this is missing I dont think there's any way of finding out exactly which scheme your bike was but the V-source site has a table that narrows down the possibilities dependent on chassis and engine numbers.
which undertray is that, the plastic bit under the rear seat that holds the battery?
- jim157
It should be visible when you remove the passenger seat, its next to where the toolkit sits.
AUTOEXEC.TWAT
- JZH
- Bike owned: RSCBRRVFVFRST
The color code is also on the "barcode sticker" on the rear mudguard under the number plate--if it hasn't been removed. Other than that, I'm sure Honda Japan could look up a bike's original paint scheme via the Frame Number, but that's not a service I've ever heard Honda offering to us punters...
Ciao,
Ciao,
- royster81
Check the inside of the panels ( if they are oe plastic) , the underside the fuel tank and front guard to see if there is any remence of the oe scheme, then use the frame/engine numbers to work out the year from that you should be able to limit your search down a few paint schemes
