hollow front end knock...
viper_biker
Re: hollow front end knock...
God, my back will be sore on Saturday. A chain, chain tool kit, big ratchet, extender bar and yoke socket. YOU are making the tae and coffees LOL
- royster81
so nothing different there then...dude i have to make tea and coffee when i go to yours*viper_biker wrote:YOU are making the tea and coffees LOL
*well if i want to enjoy a cuppa that is lol
- royster81
foxy bingo !!!!!!!!!!!!!1colingram wrote:Hey Royster,
There are 2 lock rings under the top yoke
carlwb3
I have the same problem but no big socket/spanner. So maybe I have 2 problems. Could someone give me a quick run down on the easiest way to do this please? I have a Haynes manual to double check... Thanks!royster81 wrote:foxy bingo !!!!!!!!!!!!!1colingram wrote:Hey Royster,
colingram
Hey Carl,
you need a 41m socket for the stem nut on the top yoke and a torque wrench as it's tight (140nm according to Haynes manual). loosen the top yoke pinch bolts (5m allen key jobby according to my dodgy memory) then pull the top yoke off. where you took the stem nut off, you will see two lock rings secured with a locking washer. First bend the lock washer tabs so you can loosen the top lock ring. Pull her off first, then tighten the bottom lock ring using precision shifting device and a drift. Lock washer back on, then top lock ring. Tighten her up, then bend the lock washer into place again. Top yoke back on etc and voila. Bike is gonna feel like brand new again for half and hour of elbow grease.
Sorry about the over explaining, but I have a habit of doing it and can't help it
If you are in NI (Belfast) area, I have the 41m socket.........
colingram
Glad I could help. Baffled the hell out of me for ages as wellroyster81 wrote:foxy bingo !!!!!!!!!!!!!1colingram wrote:Hey Royster,
- royster81
sorted today,lanky called over and we took the bike apart to sort a few things and fit a chain to the track bike.colingram wrote:Glad I could help. Baffled the hell out of me for ages as wellroyster81 wrote:foxy bingo !!!!!!!!!!!!!1colingram wrote:Hey Royster,
